mudmagnet Posted May 3, 2010 Share Posted May 3, 2010 im going to change from the rubber donut coupling on my 300tdi to a 200tdi type prop what drive flange do i need as ive been told i need one off of a defender and not a disco is this right? any help appreciated Quote Link to comment Share on other sites More sharing options...
teabag Posted May 3, 2010 Share Posted May 3, 2010 Try the 4 bolt flange from a D1 V8 that dosen't have a donut I think that's the later models like mine ie.1997. Quote Link to comment Share on other sites More sharing options...
henrycrabbe Posted May 3, 2010 Share Posted May 3, 2010 dare I say... there are some on ebay that sell complete kits, which is where my flange came from and I bought a 200Tdi Disco rear prop locally. Beware that when fitting the 4-bolt flange, some diffs need a spacer to take up the extra shaft length. Oh and it helps to heat the centering pin on the old three-bolt flange to break the seal when removing it. cheers, Steve Quote Link to comment Share on other sites More sharing options...
karlo Posted May 4, 2010 Share Posted May 4, 2010 There are 2 lengths of flanges 49mm and 61mm or Ashcrofts do a spacer which cost me about £7 delivered. http://cgi.ebay.co.uk/LAND-ROVER-DIFFERENTIAL-DRIVE-FLANGE-KIT-4-BOLT-STC4858-/260351605907?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3c9e2a3c93 Quote Link to comment Share on other sites More sharing options...
mudmagnet Posted May 4, 2010 Author Share Posted May 4, 2010 i see that devon 4x4 do a flange kit as well how will i know what length flange i need Quote Link to comment Share on other sites More sharing options...
karlo Posted May 5, 2010 Share Posted May 5, 2010 The longer one for a 300 diff, if you use a 4 bolt flange from a 200 you have to use a spacer. Quote Link to comment Share on other sites More sharing options...
