orionpco Posted May 3, 2010 Share Posted May 3, 2010 hi, i plan on converting my 64 series 2a to a 3.5liter v8. what i was wondering was if i used the series 6 cyl bulkhead would i still need to modify the bulk head for the v8 and what mods of any would be necessary from the bulkhead to the seat box. thank you guys for any and all advice. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 4, 2010 Share Posted May 4, 2010 Yes, mods are needed. Off the top of my head, you need to widen the bit between the foot wells - particularly the passenger side. And a new cover plate is needed to match it. Assuming you keep the gearbox the same, the tunnel and seatbox can remain standard. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted May 4, 2010 Share Posted May 4, 2010 As James says, just a little bit on the driver's side and a bit more on the passenger side. The bit of plating should really be welded although when I did it I riveted it in and welded it later. Can I shamelessly plug the radiator made to fit a seriesthat I am selling: http://forums.lr4x4.com/index.php?showtopic=55956 Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 4, 2010 Share Posted May 4, 2010 You may need to trim the bottom of the bulkhead where it touches the top of the gearbox adapter depending upon the adapter used? I have a Phillips adapter and I had to shave a bit off the bottom. To cover this I used an extra piece of ally to ensure the gearbox cover fitted. If you are careful (more than me)you may not need to. Whatever you need to do will all fade away the first time you drive it with the V8. Marc. Quote Link to comment Share on other sites More sharing options...
orionpco Posted May 5, 2010 Author Share Posted May 5, 2010 thanks guys i have access to a 6 cyl bulkhead from a 109 and i kinda thought that might get me out of the whole modding thing but i guess not. no worries, that v8 going in no matter what. Quote Link to comment Share on other sites More sharing options...
