marysboy Posted May 4, 2010 Share Posted May 4, 2010 Hi all. I'm repainting my hard top at the moment. I took out the rear quarterlights (the ones on the back panel either side of the rear door) and the rubber seals were absolutely shot and fell to pieces. I can't now find the sealing strip for sale anywhere! Nearest I've got is this: clicky link Anybody got any ideas? The seal I took out was in two pieces - the main seal and then a second smaller sealing bead that pushed into it. Thanks all, Ian. Quote Link to comment Share on other sites More sharing options...
marysboy Posted May 5, 2010 Author Share Posted May 5, 2010 The seal I took out was in two pieces - the main seal and then a second smaller sealing bead that pushed into it. It looked quite a lot like this clicky link but it's quite expensive Quote Link to comment Share on other sites More sharing options...
western Posted May 5, 2010 Share Posted May 5, 2010 items 26 & 27 on parts book page 882 do the same job on 90/110 & IIRC the glass is the same size. Quote Link to comment Share on other sites More sharing options...
marysboy Posted May 6, 2010 Author Share Posted May 6, 2010 items 26 & 27 on parts book page 882 do the same job on 90/110 & IIRC the glass is the same size. Thanks! Quote Link to comment Share on other sites More sharing options...
marysboy Posted May 17, 2010 Author Share Posted May 17, 2010 Okay, managed to get the windows in at the weekend. Well, almost - after fitting the main seal and glass, I couldn't then get the smaller filler strip in. Has anyone any suggestions? Cheers, Ian. Quote Link to comment Share on other sites More sharing options...
PeterW Posted May 29, 2010 Share Posted May 29, 2010 Okay, managed to get the windows in at the weekend. Well, almost - after fitting the main seal and glass, I couldn't then get the smaller filler strip in. Has anyone any suggestions? Cheers, Ian. Ian its a pain of a job, but it can be done. You may need the proper tool from someone like Woolies Trim, or you can make one with heavy wire. Needs to part the sides of the main seal and then you push the second seal in. I did the curved ones on a truck cab - first one took 2 hours, second one 15 minutes ! Cheers Pete Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 29, 2010 Share Posted May 29, 2010 This is the tool mentioned above, though it is a bit of a luxury!. Cheap washing liquid will help the fitting process, but don't go mad and rinse off as much as you can afterwards. Quote Link to comment Share on other sites More sharing options...
marysboy Posted June 1, 2010 Author Share Posted June 1, 2010 Thanks, I'll try the washing up liquid and a coathanger Ian. Quote Link to comment Share on other sites More sharing options...
