need4speed Posted May 4, 2010 Share Posted May 4, 2010 Is Bonda zinc based primer suitable to use on aluminium or is there something better. I know Bonda is a very good primer to use on steel but wasnt so sure about using it on ally... Any thoughts or experiences? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2010 Share Posted May 4, 2010 Just about to paint my Overland trailer project, after speaking to the paint guy I went for etch primer first then a high build undercoat and then the paint, the chap said if I didn't use the etch primer first the paint would just flake off in a couple of months time as no matter how much you rub down you will not be able to key aliuminium. Quote Link to comment Share on other sites More sharing options...
Mark Posted May 4, 2010 Share Posted May 4, 2010 as has been said, you really need an etch primer, or an acid etch wash before painting ally... bondaprimer is excellent stuff, but it will still need an etch on ally really. hth Mark Quote Link to comment Share on other sites More sharing options...
need4speed Posted May 4, 2010 Author Share Posted May 4, 2010 Thanks for the advice. Next question is what acid etch to use. Ive tried halfords acid etch before and it is complete carp... :-( Quote Link to comment Share on other sites More sharing options...
Guest Posted May 4, 2010 Share Posted May 4, 2010 Thanks for the advice. Next question is what acid etch to use. Ive tried halfords acid etch before and it is complete carp... :-( I got mine from a local auto paint supplier, will look at the make in the morning for you it is a two part job activator and primer, same one I used for the series one and 3 years later the paint is still on!!! Quote Link to comment Share on other sites More sharing options...
need4speed Posted May 4, 2010 Author Share Posted May 4, 2010 Thanks Jason. I take it i will be able to apply the bonda primer on top of this ok? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2010 Share Posted May 5, 2010 I assume so, I am just using a high build prima which i beleive bonda primer. Will take a photo of the primer tonight. Jason. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 5, 2010 Share Posted May 5, 2010 Go to your nearest auto paint factors and discuss what you want to do with them, they will be able to advise and supply systems that won't adversely interact with one another. Quote Link to comment Share on other sites More sharing options...
