gasbatalla Posted May 4, 2010 Share Posted May 4, 2010 Hi, does anybody knows the part number for this pieces. Is for a Defender 90 1998 Universal Joint Indicator Relay Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2010 Share Posted May 4, 2010 The steering column UJ's are Upper NRC7387 & Lower NRC7704 flasher relay is RTC3562 Quote Link to comment Share on other sites More sharing options...
gasbatalla Posted May 7, 2010 Author Share Posted May 7, 2010 The steering column UJ's are Upper NRC7387 & Lower NRC7704 flasher relay is RTC3562 Do all three work even though mine is a 1998 model? Quote Link to comment Share on other sites More sharing options...
western Posted May 7, 2010 Share Posted May 7, 2010 click the links & check the chassis number info in each link, if your vehicle is Defender upto vin VA133508 then these will fit, the flasher unit part number has been superseded so the later version should also be a direct fit. Quote Link to comment Share on other sites More sharing options...
gasbatalla Posted May 10, 2010 Author Share Posted May 10, 2010 click the links & check the chassis number info in each link, if your vehicle is Defender upto vin VA133508 then these will fit, the flasher unit part number has been superseded so the later version should also be a direct fit. My VIN is SALLDVAF8WA151357 any idea where i can get these parts? Quote Link to comment Share on other sites More sharing options...
gasbatalla Posted May 13, 2010 Author Share Posted May 13, 2010 Anyone? Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2010 Share Posted May 13, 2010 Click the links above & you'll find a supplier. Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 13, 2010 Share Posted May 13, 2010 Click the links above & you'll find a supplier. Or just Google the part numbers Ralph has given you. If you put your location (country / island / state / city) in your signature this will help us help you too. Quote Link to comment Share on other sites More sharing options...
gasbatalla Posted May 14, 2010 Author Share Posted May 14, 2010 Thanks for the answers. I live in Costa Rica, but it doesn't matter were the part gets ship from as long as it works. Defender 90 1998, VIN SALLDVAF8WA151357 Quote Link to comment Share on other sites More sharing options...
