TheRecklessEngineer Posted May 4, 2010 Share Posted May 4, 2010 Updated version It's all here now, except for peoples running issues. I'll go through these at some other time, and possibly make this a little easier to read. If there's anything I've missed, let me/Nige know. I've spent far too much time wading through Nige's excellent Megasquirt thread trying to find info that I know is in there somewhere. So here is an index. Actually, I only got to page 16 before getting thoroughly bored, but most of the good stuff is here. Mods - is there an option to let me edit this and add more at a later date? Nige's build What is Megasquirt? Intro and Nige's build Nige's PWM idle valve Flapper to MS wiring diagram, AFM replacement, Custom loom manufacture More devils knitting RR in tank FP conversion More loom, finalising bits 'n' bobs Heater pipes Finalising the loom It won't turn off! Diodes and alternator wiring Loom finalisation More diodes and alternator wiring. Running stage. Loom wrapping, tidying etc. Waterproofing the MS box Extra fuel filter, engine breather re-routing Very smart chopped dizzy LCD Dash LCD Dash details/info/software etc. Box for LCD Dash So it is waterproof then... Bling bling rockers, and the dangers of Bosch PWM vavles LCD Dash upgrade to tablet PC Starting improvements, PWM valve additon. Nige's spangly new exhaust Nige being very honest about his electrical abilities and the ease of using MS Other builds landybehr coil mounts and wiring Tuning Nige's excellent tuning explanation And BBC's notes on the above. Narrowband VS Wideband Timing advance on an RV8 Discussion of a valley in the spark table Nige's tuning progress Nige's further tweaks Nige's explanation of MegaLogViewer and how to use it. Further info on maximum advance on an RV8 Coping with large files in MLV Nige's explanation of MLV v2.94 and how to tune: After start enrichment, Warm up Enrichment, PWM valve, More on Nige with WUE, and Tuner Studio Getting tuning software running on Win98 How to run Megatunix using a bootable USB linux image Aaron_h on MOT emisson tuning HFH on differing advance curves, and effects of rain on O2 sensor FF on how to setup MT for different firmware versions Hunting due to O2 correction at idle. Nige on tuning acceleration enrichment Explanations of stuff/Discussions Megatune, EasyTherm, Megalogviewer and what it all means Earths back to ECU MS hardware and software versions, PC software and what they all are Discussion of noise suppressing capacitors How to make your own ignition leads/discussion therupon Electrocution (or lack of) from a VR sensor PWM Idle valves, setting up from BBC Further thoughts on the above Yes, more PWM valve advice from BBC. USB/Serial adapter discussion, Maplin one OK BBC's explanation of IAT heatsoak and solution, and corresponding discussion Setting up MS hardware for MS extra 3.9 serpentine differences for MS Setting up trigger wheel for EDIS (by Nige) Setting up trigger wheel for EDIS (By FF) FF on zones of fuel/spark tables FF on narrowband sensors and relationship to AFR Setting up MS to drive cooling fans, and running temps for RV8s Thoughts on coil on plug systems Removal of the cold start injector on flapper systems PWM idle valve vs stepper motor. Possible stepper motor on MS1 Adding a fast idle button for winching etc Direct drive ignition driver order Driving cooling fans, strange problems with permenant lives Spark/Fuel tables 4.6 Ignition map, TomG BBC's Ignition map. 3.9? A bit whizzy. BBC's 3.9 MSQ (Fuel and spark) Nige's Eales maps, Safe and *ahem*...not so safe. istruggle2gate11 Fuel and spark maps. Megajolt spark table, 3.5 on carbs (John White) Standard dizzy timing MS_N_EDIS_Popular defaults - will start and run almost any RV8 Downloads DIY Autotune's free software package MS Extra 029v firmware, downloader, asm code and compiler 029v firmware another download link Diagrams EDIS 8 ignition lead order MS n EDIS complete wiring diagram, flapper colours, EDIS 8 ignition lead order and MS connector pinout MS Pinout Piccies/diagrams of PWM and EDIS mods Another EDIS 8 plug diagram Useful info Alternating vs Simultaneous and AEnrichment PWM idle valve, suitable donor vehicles/part numbers. Settings for RR temperature senders, and .ini file Bosch coolant and air temp sensors, part numbers Air temperature sender part number Shopping list for MS'ing a V8 Voltages and pins on MS ECU/EDIS unit A good Q&A on basics of MSing 3.5 flapper Peoples problems and solutions Tarmacshredders problems with direct drive Quote Link to comment Share on other sites More sharing options...
