andrew69 Posted May 4, 2010 Share Posted May 4, 2010 hi thinking of changing my oil bath /air filter to a more modern set up what and where to get best kit.its a 2.5diesel series2a. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 4, 2010 Share Posted May 4, 2010 If you have the 2.5 N/A in a S2, then whoever did it, plumbed the engine into the original oil bath filter - designed for the 2.25. Nothing wrong with that in itself, but it's more convenient to install the paper element filter. You can cut the oil bath support bracket off the end of the battery tray and install a paper element filter in it's place. There'll be some pipework to fiddle about with though. Les. Quote Link to comment Share on other sites More sharing options...
andrew69 Posted May 5, 2010 Author Share Posted May 5, 2010 If you have the 2.5 N/A in a S2, then whoever did it, plumbed the engine into the original oil bath filter - designed for the 2.25. Nothing wrong with that in itself, but it's more convenient to install the paper element filter. You can cut the oil bath support bracket off the end of the battery tray and install a paper element filter in it's place. There'll be some pipework to fiddle about with though. Les. hityping error its a 2.25 diesel, Quote Link to comment Share on other sites More sharing options...
Dark green 90 Posted May 5, 2010 Share Posted May 5, 2010 The best kit is....the oil bath filter, simple and cheap. Why change it? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted May 7, 2010 Share Posted May 7, 2010 The best kit is....the oil bath filter, simple and cheap. Why change it? Absolutely agree: The BEST system for a non turbo engine is an oil bath. No ifs, no buts, no maybes. Clears the air best - and diesels need pure air. G. Quote Link to comment Share on other sites More sharing options...
