kingrat Posted May 5, 2010 Share Posted May 5, 2010 Well it took me 3hrs to get the steel sheet blanking plates out. They had been pressed in before the door was skinned and the welded into the frame. 3mm thick steel plate, Ralph was right. Windows fitted to one side only as I found that the doors are late (as to be expected) but the regulators I hade recovered from some scrap doors are early. I think I need CVH500080 and CVH500090, but it seems odd that the 2nd row doors use the same regulator as the front. Word of caution to all. A universal electic window kit only works if you have a splined regulator fitted (still I now have electrikey front windows) Any thoughts on if these regulators will work in 2nd row doors? Quote Link to comment Share on other sites More sharing options...
