SRS & Co.
mbm
SRS light went on.
The LR dealer solved this problem... for 2 or 3 days; this "efforts" were repeated 3 or 4 times.
Then they changed drivers seatbelt (LHD) and things went worst:sometimes I am unable to close the sun roof with the key; sometimes I get the message "left window not programed", sometimes the horn doesnt work(SRS light always on). More 3 trips to the dealer and one or all these malfunctions remain. LR dealer says that the rotary coupler is ok (my gess as the horn isn't working properly) and that sometimes the best thing to do is to shut down the engine and go on again. I think they are not able to do the job, but it´s the only I can get around.
So, any inputs on how I can try to press them in the right direction will be apprecited.
Thanks,
What error message is stored in the Airbag ECU? Will the horn work if you shorten the respective cables under the dash? If the first one is related to the drivers airbag and the sencond answer is yes these faults should be related to the coupler. It might work intermittantly but airbag faults will not clear by themselves.
If the other faults are related the BECM might have started to pack up.
Cheers
Carsten ;-)
  • 3 weeks later...
