no guts
godzilla
Add Tornado Chips and upgrade the plug leads but you will be spending £600 to £700. Upgrade cylinder heads, camshaft stage 1 or 2 if you want to get more.
Why do you need more out of a 4.6? mine will do plenty enough with the chipset don't forget this a very heavy 4X4.
I'm not really into modern diesels but 'Parkers' list the 2.7 @ 205 bhp (vs 225 for the 4.6) but doesn't quote the all -important torque figure for the Citroen. If you compare the power-to-weight ratio of the two vehicles (& remember that the RR is subject to a much greater power-loss through it's complex transmission) you will see why the 'Cit' performs that much better! It's the old case of 'horses for courses'
