the real muddy90 Posted May 11, 2010 Share Posted May 11, 2010 We've persivered with the 2a for 4 trials now, the first 2 had carb probs but all had trouble getting gears. When the misses bought it from a mate it became apparent he'd just thrown it back together, I had to undo so much of his bodging! Anyway, I'm kinda thinking that when he put the engine & box back in the new chassis he's done summat stupid with the clutch release thingamajig. But what??? I've taken slack up at the pedal & master cyl but from the slave push rod to the link bit it has huge amount of play, maybe half the push rod Seems the release bearing isn't coming back far enough. So.... before I pull the engine or box out (not decided which is easier yet!) any ideas??? Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 11, 2010 Share Posted May 11, 2010 Check that both the cross shaft pins are intact and not broken. Quote Link to comment Share on other sites More sharing options...
the real muddy90 Posted May 12, 2010 Author Share Posted May 12, 2010 I'll check that ta. Would it be possible for him to have fitted the wrong clutch??? Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted May 12, 2010 Share Posted May 12, 2010 Its vital that proper Rover pins are used in the clutch cross shaft. They are very hard and will survive and do the job. Bolts will NOT do - and will quickly shear - which is not necessarily visible until you dismantle it. I've seen the slave cylinder fitted the wrong side of its bracket on the bellhousing to get more travel. Not recommended but it worked! Quote Link to comment Share on other sites More sharing options...
the real muddy90 Posted May 16, 2010 Author Share Posted May 16, 2010 I've seen the slave cylinder fitted the wrong side of its bracket on the bellhousing to get more travel. Not recommended but it worked! I did toy with the idea of fabbing up a longer push rod for the slave cyl or putting the slave under the bracket. I don't think it would disengage the clutch plate any more though. I'm going to have to ask the guy we got it from if he did anything to the clutch. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 17, 2010 Share Posted May 17, 2010 I'll check that ta. Would it be possible for him to have fitted the wrong clutch??? Yes it is possible. A 2a gearbox used to run with a 9" coil spring pressure plate that was superceeded with a diaphragm spring cover that had a boss on the middle to bear on the release sleeve. If some joker has replaced this later 2a cover with a series 3 diaphragm cover cos its cheaper it will cause problems as it does not have a boss in the middle. Quote Link to comment Share on other sites More sharing options...
the real muddy90 Posted May 30, 2010 Author Share Posted May 30, 2010 Yes it is possible. A 2a gearbox used to run with a 9" coil spring pressure plate that was superceeded with a diaphragm spring cover that had a boss on the middle to bear on the release sleeve. If some joker has replaced this later 2a cover with a series 3 diaphragm cover cos its cheaper it will cause problems as it does not have a boss in the middle. Cheers Phil, That's actually a great help I have asked if the previous owner put a clutch in when he started rebuilding her but he said he didn't split the gear box/engine. That's not to say nobody else has! Gives me something to look for when I do get round to it. Quote Link to comment Share on other sites More sharing options...
