Oakmaster Posted May 13, 2010 Share Posted May 13, 2010 Further to the questions re: Brake up-grade posted above – I'd welcome any advice you can share with regard to the correct choice of tyres essentially for on-tarmac, road use. I commute to work in a 1989 110 V8 Pick-up via narrow single track twisty lanes, and B roads, is rural, hilly, often damp, and can involve leaves, and agricultural activities. I have scared my self witless (that's Wit with a ‘W’) on a couple of occasions, so I need to improve my stopping distances. Especially in the wet. Currently using a rag tag mix (that were on it when I bought it) mix of BFG and Colway 265/75 16s So starting with a blank sheet of paper and a sensible budget – what would you use? Thanks Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 13, 2010 Share Posted May 13, 2010 Agricultural activities, does that involve field work here and there? I believe a set of all-terrains in the standard fitment size (which for a 110 is 235/85/R16 I think) would do you well. BFG make a good one, very highly regarded, but there's also the General Grabber AT2. I personally wouldn't put anything 'less' than an AT pattern tyre on, it is a Land Rover after all Quote Link to comment Share on other sites More sharing options...
