heath robinson Posted May 16, 2010 Share Posted May 16, 2010 The T-wash isn't darkening all of my chassis. I did it once, after removing any grease etc, and hosed off, then the whole thing went white... I washed it all down with a cloth and applied it again, giving it a good scrub as it went on, but there's still patches that look shiny... Any Ideas? Ta, Jake Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted May 16, 2010 Share Posted May 16, 2010 have used t-wash as a pretreatment for painting on top of galve,in my experience you will never get a full consistant coverage,because by nayure the galv is not flat or smooth. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 16, 2010 Author Share Posted May 16, 2010 That's what I'm using it for, but it doesn't seem to even lightly darken some areas. I'll see how it looks in the daylight, but what do you reckon is acceptable for painting onto? The paint I'm covering it with is Intercure 200, so I don't want to get it wrong... Thanks, Jake. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted May 17, 2010 Share Posted May 17, 2010 In my experience there are always bits that look like you've missed them, some bits go black instantly (most of it), and some bits show no sign of change. I wouldn't worry. Wash it off, maybe degrease it once more, and then on with the paint. Al. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 17, 2010 Author Share Posted May 17, 2010 Nice, thanks. It's a little worrying to think that it'll fall off again after all this trouble, but I guess that it 'll be fine after the second go. Cheers, Jake Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 17, 2010 Author Share Posted May 17, 2010 Riiiiight then... Almost none of it's gone black, only the occasional patch. Most of it's just not shiny any more. Actually, I'll get the camera. What follows is after washing, degreasing, t-washing by brush, hosing off, sponging off, t-washing again, then sponging and powerhosing. Arrrrrggggh! Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 17, 2010 Author Share Posted May 17, 2010 Here's the thing immediately after pressure-washing. It's gone white again in the sun, with salt-like deposits. And here's the bit that nearly went black. Heeeeeeeelp! Any thoughts? Quote Link to comment Share on other sites More sharing options...
gruntus Posted May 17, 2010 Share Posted May 17, 2010 Hi Jake, Apparently its natural for the galving to come off and for salts to appear when the zinc gets wet, my new galv chassis has salts all over it and wondered what it was to start with. Theres a good link here but there was a good one raised recently (that I cant find! ). The link I was looking for was from a chap where a lot of the galving had come off due to road salts in winter and was quite frightening how quick it was coming off compared to the age of the chassis. Personally i have missed the boat for painting my chassis when it was bare however I am just going to liberally apply two coats of waxoyl to the complete chassis by brush and touch it up once a year where needed. HTH G Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 17, 2010 Author Share Posted May 17, 2010 According to that thread, the t-wash should make it go black... It ain't doing that much to mine... Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted May 17, 2010 Share Posted May 17, 2010 your photo shows much the same result as we had at work,but the paint sticks,the bits we did were for a ship to shore crane on felixstowe docks. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 17, 2010 Author Share Posted May 17, 2010 Ahhh, relief. Ok, thanks mate, I'll paint it and stop worrying. Cheers, Jake Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted May 17, 2010 Share Posted May 17, 2010 Don't worry, it partly depends how long ago it was galved etc. just whack it on, wash it off, and then proceed. You'll be fine - sounds like you've done a good job. Ignore what it looks like. Have faith! Al. Quote Link to comment Share on other sites More sharing options...
heath robinson Posted May 22, 2010 Author Share Posted May 22, 2010 Thanks all, now undercoated, and it looks great. I tried scraping a bit off, and found that it's well and truly stuck on. I can thoroughly recommend Intercure 200 paint, if you can find it at a reasonable price (Like from a forum member ). 2/3 of a paint-mixing cup weighs about 1 kilo! It nearly burnt the drill out mixing the colour part though, a bit thick. Thanks for the reassurance. Jake Quote Link to comment Share on other sites More sharing options...
