DAN82SED Posted May 16, 2010 Share Posted May 16, 2010 was wondering if anyone had experienced this problem, its an r380 im having problems making a smooth change from first to second gear, gear oil has been changed and showed no sings of metal or copper fillings. it is only gringing from 1st -2nd, every other gear is fine. if i change gear by lifting the gear leaver up and then slot into 2nd it reduces/ stops the grinding. im hoping its only the clutch that needs adjusting because it has roughly 4" of movement before you get any resistance and it sits a lot higher that the brake and accelerator pedel. also , changes gear perfectly for first couple of minutes of driving, but as son as it warms up, the grinding starts any ideas guys Quote Link to comment Share on other sites More sharing options...
PaulN Posted May 17, 2010 Share Posted May 17, 2010 Notoriously common notchy 2nd gear on the r380. Change oil to MTF 94. I've sorted mine by using this on my Disco but some on this Forum use 'Difflock's' varient, though expensive, to good effect. No doubt a more experienced member will confirm this but I had the exact same problem and the MTF 94 sorted it. Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted May 17, 2010 Author Share Posted May 17, 2010 cheers mate, ill give it a go, gonna be cheaper than a new gearbox Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 17, 2010 Share Posted May 17, 2010 Sort your clutch pedal adjustment out too, it won't be helping. HTH Mo Quote Link to comment Share on other sites More sharing options...
DAN82SED Posted May 17, 2010 Author Share Posted May 17, 2010 cheers mo, definatly goona sort the clutch as well, ill add it to my never ending to-do list.the joy of buying a neglected land rover Quote Link to comment Share on other sites More sharing options...
