joe sharpe Posted May 20, 2010 Share Posted May 20, 2010 hi all i have just replaced calipers on my 91 h discovery 200tdi and bled them with a eezi bleed no air in system,brakes work but constant pressure on peddle and it drops to just under half way down,will it be air somewhere or something else ????need help cheers joe Quote Link to comment Share on other sites More sharing options...
gripper Posted May 22, 2010 Share Posted May 22, 2010 better to bleed them manually if you can it's better than an easi bleed, have you remembered there are 3 nipples on the front? i think that's right. also my mate lost his pedal last week whilst laning, there were no leaks anywhere it turned out to be the servo. try it with the vacuum pipe removed. Quote Link to comment Share on other sites More sharing options...
