SteveG Posted May 15, 2006 Share Posted May 15, 2006 Anyone know a source of the black mastic that LR use on door/room frames etc to fill the gaps etc. Seems to work best in my opinion so I want to get some more to finally do my door seals properly. Thanks Steve Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 15, 2006 Share Posted May 15, 2006 Anyone know a source of the black mastic that LR use on door/room frames etc to fill the gaps. They fill the gaps on some? Can't say I ever noticed one like that Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 15, 2006 Author Share Posted May 15, 2006 They fill the gaps on some? Can't say I ever noticed one like that Should have been door/roof frames don't know where room came from as 'f' is no where near 'm' Steve Quote Link to comment Share on other sites More sharing options...
geoffg Posted May 15, 2006 Share Posted May 15, 2006 Do you mean something like sikaflex Quote Link to comment Share on other sites More sharing options...
western Posted May 15, 2006 Share Posted May 15, 2006 It could be LR part number 78159 the black glazing sealant as used on the rear door to seat the glass into. Quote Link to comment Share on other sites More sharing options...
scrumps Posted May 15, 2006 Share Posted May 15, 2006 It could be LR part number 78159 the black glazing sealant as used on the rear door to seat the glass into. The black stuff around the windscreen to bulkhead joints (under the door seals) is "dum-dum sealant putty". Used it for years on classic cars etc. Someone is selling a couple of tins on e-blag for £5.99 at the moment. It remains flexible and doesn't dry out or cure like silicone etc. Regards Scrumps Quote Link to comment Share on other sites More sharing options...
jules Posted May 15, 2006 Share Posted May 15, 2006 The black stuff around the windscreen to bulkhead joints (under the door seals) is "dum-dum sealant putty". Used it for years on classic cars etc. Someone is selling a couple of tins on e-blag for £5.99 at the moment. It remains flexible and doesn't dry out or cure like silicone etc. Regards Scrumps Yes and you will be getting covered in it every time you touch the door frame and every time you get in and out be there done that As I have a box on the floor next to my desk in my site office Dow Corning 791 weatherproofing sealant Neutral Silicone High Movement (takes about 48hr to go off properly but stays very soft and rubbery for about 10 years) That's what My glaziers use and I use on my racers and 90 for sealing up gaps in roofs and body work. cost at a builder merchants between £3-7 Quote Link to comment Share on other sites More sharing options...
Gnomeranger Posted May 16, 2006 Share Posted May 16, 2006 Sikaflex or Tigerseal Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted May 16, 2006 Share Posted May 16, 2006 Sikaflex, Tigerseal or Carbond. All good stuff and will ensure a pretty permanent bond. Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted May 16, 2006 Share Posted May 16, 2006 Anyone know a source of the black mastic that LR use on door/room frames etc to fill the gaps etc. Seems to work best in my opinion so I want to get some more to finally do my door seals properly.Thanks Steve Dum Dum putty is the stuff. Getting harder to get hold of these days as most auto paintshops have swapped over to modern Sikaflex, Tigerbond type materials. Search for 'dum dum' at Frost Auto restoration. £5.00 a tin. Kev Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 17, 2006 Author Share Posted May 17, 2006 Cheers for the replies everyone. Yes I used the flexible sealant already but the putty seems to be better at filling the bigger gaps found on a LR, especially mine with panels from various models Cheers Steve Quote Link to comment Share on other sites More sharing options...
