Les Brock Posted May 21, 2010 Share Posted May 21, 2010 Jez's old (well meuseum piece in all honesty) Might even have been Fridges............not sure on that either TBH spec he posted up if tis the same one... That I now have Eurotoch fitted, I did however remove the Bling Blue LED Fans from underneath taking it down some stairs...easier said than done, had a bad back ever since !!!!!!!!!!!!!!! Not 100% sure on the Ampage TBH Trying to find out the rough amperage for the switch positions ? I did try taking open circuit voltage for each position if it would help ? , but left the info at home Closest pics I can get to what it looks like Front is like this one but with eurotorch no current marked Reel lays flat inside ! Ta...................................................................................... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 21, 2010 Share Posted May 21, 2010 That were Jez's one, mine is still in my shed. Think the top amps are 160 ish, and they're full-fat amps not semi-skimmed hobby mig ones Quote Link to comment Share on other sites More sharing options...
