RWelbourne Posted May 21, 2010 Share Posted May 21, 2010 Hi, I am after a snorkel to fit to my TD5 90. I have a North Off Road cage fitted and am after one that goes through the vent on the top of the wing. I will also need one the same on the other side as i want my heater to work (unlike in my old 90) Any idea where to get them from/who can make one. Would like one made from one solid piece if i can, but all depends on price. Thanks, Pete Quote Link to comment Share on other sites More sharing options...
old leafer Posted May 21, 2010 Share Posted May 21, 2010 i am sure southdown do one for roll cages hope this helps Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 21, 2010 Share Posted May 21, 2010 I think protection and performance will bend you one up. I made mine from exhaust parts (new pre shaped tubing) and then welded it together. Dave. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2010 Share Posted May 21, 2010 Be Prepared for cost, I have a Mantec Snorkel for my 110 TD5, -RC on the end of the part number added £50, for a pipe welded at a diffrent angle and some roll cage clips!!!! I struggled to find a Roll cage snorkel as I didn't want to cut my wing, and even considered talking to Scrapiorn at one point!!! (it got that bad honestly!!) you may have more luck, although mine is connected to the side vent not the top of the wing also. Jason. Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 22, 2010 Share Posted May 22, 2010 Mantec V8 snorkels fit to top of wing vent and fit to cage ok. I had one on my V8 50th. Quote Link to comment Share on other sites More sharing options...
sean f Posted May 22, 2010 Share Posted May 22, 2010 Have you tried asking North Off Road?. They may not list one but you can't be the first person to want a snorkel with one of there cages. I found them very helpfull when I spoke to them so if they cannot supply one which fits well they maybe able to point you in the right direction. After all they know the shape and dimensions of the cage!. Not an easy thing for manufactures to make as beside the normal huge tolerances for all LR's no two roll cages are the same and many are one off's in terms of cage and engine with all sorts of other mods as well. Quote Link to comment Share on other sites More sharing options...
antony110 Posted May 22, 2010 Share Posted May 22, 2010 I have looked into this as I have a safety Devices roll cage on my 90. Southdown make them for rollcages, Southdown is great quality they sell thier slight seconds on ebay, if you type this number into the search box you will find a kit but, look at there other items to. 310184677927 Quote Link to comment Share on other sites More sharing options...
RWelbourne Posted May 22, 2010 Author Share Posted May 22, 2010 Thanks for the help. I had looked at southdown ones, but i want it to go through the vent on the top of the wing so the heater can have one too... Quote Link to comment Share on other sites More sharing options...
tricks Posted May 23, 2010 Share Posted May 23, 2010 I was looking around like yourself finally found it was easiest to use a local stainless exhaust shop they are happy to knock up whatever i want however i want it im just going for stainless pipe out of the wing top and then either a mushroom or a K&N on the end Im using www.tonybanks.co.uk if thats of any help to you all the best James Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 24, 2010 Share Posted May 24, 2010 After doing similar reserch, I decided to get the wing part made up. quite easy, not got round to making a pettern yet though. http://www.devon4x4.com/products_b/p14272c-2/0/mantec-snorkel-nas-spec.html --- or the rather pricey alternative. Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted May 24, 2010 Share Posted May 24, 2010 the winterised/wading pre wolf MOD lanny's had a wing top snorkel that replaced the heater inlet grill on top of the wing similiar to the Mantec setup but for the RHD heater side. Trouble is they're rare-I cant find a picture, Ebay is your best bet and where I should the two I had. Quote Link to comment Share on other sites More sharing options...
