Bigant Posted May 26, 2010 Share Posted May 26, 2010 Dear All I have just fitted a recon gearbox and I now need to fill it with oil, can I fill it by removing the copper coloured nut covers on the top of the main and transfer boxes or do I have to use the fill/level holes on the sides? Secondly, how much oil should does the box take? Cheers Bigant Quote Link to comment Share on other sites More sharing options...
RobotMan Posted May 26, 2010 Share Posted May 26, 2010 Do not undo those! Use the filler plugs on the side, fill to level of plug. Quote Link to comment Share on other sites More sharing options...
Bigant Posted May 27, 2010 Author Share Posted May 27, 2010 Do not undo those! Use the filler plugs on the side, fill to level of plug. Hi Thanks for the warning, I will use the filler plugs on the sides as you have suggested, what happens if you undo the copper coloured nuts? Regards Bigant Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted May 27, 2010 Share Posted May 27, 2010 TWANG goes a selector spring Quote Link to comment Share on other sites More sharing options...
