reb78 Posted May 27, 2010 Share Posted May 27, 2010 The lower bolt that holds the gearbox casing to the transfer box is weeping EP90 on my LT230. Will PTFE tape put up with the temperatures and oil if i put this round the bolt to seal the thread or would i be better smearing the thread in instant gasket before i tighten it up? Thanks Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 27, 2010 Share Posted May 27, 2010 As Plumbers use PTFE tape on pipes and the likes for hot and cold water I'm guessing it should be ok. That said I think I would try the PTFE tape first anyway and see how it holds up before using instant gasket. Quote Link to comment Share on other sites More sharing options...
