EdF Posted May 27, 2010 Share Posted May 27, 2010 Before I spend a hundred quid, could some kind bod measure the height of the towball off the ground on the lowest setting please? I need to check if the towball would be lower than on my LR supplied adjustable towbar. Need to get the towball lower than it is now without using a drop plate - it's a heavy trailer.. Measure to the top of the towball please? Many thanks!! Mine's a 2002 90 with standard rear springs.. Quote Link to comment Share on other sites More sharing options...
matthew74 Posted May 27, 2010 Share Posted May 27, 2010 From the bottom of the rear cross member to the top of the tow ball its 3 inches on mine. There's another set of holes on the adjustable plate that the tow ball is attached to which should give you another 2 inches drop. Quote Link to comment Share on other sites More sharing options...
V8 90 JON Posted May 27, 2010 Share Posted May 27, 2010 i have a dixon bate tow bar recently removed from my 90, for sale any use to you? £60 +postage Quote Link to comment Share on other sites More sharing options...
