landy V8 Posted May 28, 2010 Share Posted May 28, 2010 hi as it says really.anyone know the torque setting for the rear wheel hub on a TD5. many thanks Quote Link to comment Share on other sites More sharing options...
ches Posted May 28, 2010 Share Posted May 28, 2010 taken from Rave. Quote Link to comment Share on other sites More sharing options...
SCADA Posted May 29, 2010 Share Posted May 29, 2010 Hi, Just to conform that I have the same information in my Haynes handbook for the hub torque settings. I replaced my front hub last weekend and it came off without any problems as I had a 3/4 drive extension bar that is 36 inches long, so the nut came off without any problem. Problem is getting a torque wrench that will go up to 490Nm or 362Lb/Ft suggest you ask politely at your local tyre outfit if they would check it for you if you dont have a suitable wrench. cheers, BK. Quote Link to comment Share on other sites More sharing options...
