forestrynick Posted May 28, 2010 Share Posted May 28, 2010 Hi all Anybody know who OE manufactuer is for drop arm ball joints, i.e the rebuildable one at steering box end of drag link. Also anybody got tips for rebuilding one (with new bits of course). Thanks Nick Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2010 Share Posted May 28, 2010 these 2 threads in our tech archive might help http://forums.lr4x4.com/index.php?showtopic=14338 http://forums.lr4x4.com/index.php?showtopic=10088 Quote Link to comment Share on other sites More sharing options...
forestrynick Posted May 28, 2010 Author Share Posted May 28, 2010 these 2 threads in our tech archive might help http://forums.lr4x4.com/index.php?showtopic=14338 http://forums.lr4x4.com/index.php?showtopic=10088 Spot on thanks Quote Link to comment Share on other sites More sharing options...
jbs Posted May 29, 2010 Share Posted May 29, 2010 Nick is it possible that you could change it over for a disco 1 solid drop arm? if you do a search on here there was a thread running a while ago on how and what you need to do the swap-this'll save you doing this again and again-instead of taking you say a couple of hours changing the drop arm ball joint it now takes me 10 minutes at the most to change the track rod end that replaces the ball joint, which is not only time saving also stops the frustration kicking in and it also last's longer with changing it over to the disco 1 drop too. HTH John Quote Link to comment Share on other sites More sharing options...
