jasonf Posted May 29, 2010 Share Posted May 29, 2010 anyone know how tight my torque bolts to the flywheel should be on an isuzu Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted May 29, 2010 Share Posted May 29, 2010 If it's the 10mm torque converter to flex plate bolts it's 37 ft/lb's. I put a drop of threadlock on for good measure. Quote Link to comment Share on other sites More sharing options...
jasonf Posted May 29, 2010 Author Share Posted May 29, 2010 ta Paul Quote Link to comment Share on other sites More sharing options...
jasonf Posted May 30, 2010 Author Share Posted May 30, 2010 paul i wonder if you can help with this after taking my torque convertor off the flywheel off my 4jb i have found the circular spacer behind the convertor to have snapped off round one of the mount bolt holes is there a part num for this item? or is a made up part its about 12 inch,s diameter and 2-3mm thick thanks jason Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted May 30, 2010 Share Posted May 30, 2010 That's called the flex plate, they are well known for cracking. Is it a Landrover gearbox mounted with a adaptor plate to a Isuzu engine? V8 or Tdi autobox? Do you know if that part is Landrover or Isuzu? Uprated Landrover one here for Tdi. Quote Link to comment Share on other sites More sharing options...
jasonf Posted May 30, 2010 Author Share Posted May 30, 2010 yes paul that looks like the baby its an isuzu 4jb mounted to a zf 4hp22 auto box god knows if the torque and flex plate are lr or isuzu thou Quote Link to comment Share on other sites More sharing options...
