Anderzander Posted May 30, 2010 Share Posted May 30, 2010 I've arranged to take my 2000 Td5 over to Bell Auto Services in mid June for a re-map. So prior to that I've been doing little outstanding jobs to get it ready, FPR leak etc. One of the things I've done is plug it into my friends Nanocom to check for faults. What its turned up is that Nanocom is saying that all 5 injectors have the same code. Apparently this is as likely as winning the lottery .... They have been recorded as: INJECTOR1: NC NC 0-M-A INJECTOR2: NC NC 0-M-A INJECTOR3: NC NC 0-M-A INJECTOR4: NC NC 0-M-A INJECTOR5: NC NC 0-M-A So my plan is to get a new cam cover gasket and lift the cover to read the codes directly from the injectors- so that we can put these in before I take it to be mapped. I've seen this thread, with a bit of info from Porny - though I'm still not clear what the last two letters on the ECU are given that the injector only seems to have 5 letters, where the 5th is converted to a number. Can anyone point me in the right direction please? Also which is injector 1? Quote Link to comment Share on other sites More sharing options...
SiWhite Posted May 30, 2010 Share Posted May 30, 2010 Can't help with the injector codes but I do know that the rocker cover seal is reusable - just put two tiny blobs of instant gasket either side of the semi-circular cut out.... Quote Link to comment Share on other sites More sharing options...
western Posted May 30, 2010 Share Posted May 30, 2010 on a inline engine injector/valve/cylinder 1 is always at the fan/radiator/front end of the engine. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 30, 2010 Author Share Posted May 30, 2010 That's good info guys, thank you. Quote Link to comment Share on other sites More sharing options...
yella 90 Posted May 30, 2010 Share Posted May 30, 2010 ignore the codes that nanocom give you, just get the 5 letters of the top of the injector and put that into nanocom, it will then turn that into the relivent code Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 30, 2010 Author Share Posted May 30, 2010 Great! Thank you very much Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 4, 2010 Author Share Posted June 4, 2010 An update: Got time to pop the cylinder head cover off today and jot down the injector codes... they are all totally different. Each one has the 5 letters and also a large single number on them too, not sure if that is supposed to correlate to which cylinder its in? if so number 5 would be at the front and has been changed ? ? .. Reading from the back of the engine to the front: 1 NGBBA 2 NCLBA 3 LFGFA 4 NMNNA 1 NCLCC Can anyone confirm what Ralph said, that the cylinder at the front of the car, on a Td5, is no.1? So that when I program them in its all on the right place. I'm also curious as to how the codes ended up being all the same ... ? I wonder if it was a new ECU and that was the default? Any guesses? Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted June 4, 2010 Share Posted June 4, 2010 Landrover number the cylinders conventionaly. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 4, 2010 Author Share Posted June 4, 2010 Thanks For mine the plot thickens - the part number recorded through Nanocom is NNN000120 - ie the later flashable ECU. So my guess is that mine has had a new ECU, the later type, and that's why the injector codes are as they are. I only hope they uploaded the necessary EU2 files to it .... Config. tune ID:sttlp009 Fuel tune ID:sthle022 ECU Part number:NNN000120 Homologation:4143 I've no idea! ? Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2010 Share Posted June 4, 2010 Drop Ian [Porny] on here a PM, he deals with Td5 electronics all day. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 4, 2010 Author Share Posted June 4, 2010 If I send any more PM's or emails I'll be done for harassment Ralph! I've been trying to get a message to him for a couple of weeks to buy an EGR kit. Quote Link to comment Share on other sites More sharing options...
western Posted June 4, 2010 Share Posted June 4, 2010 If I send any more PM's or emails I'll be done for harassment Ralph! I've been trying to get a message to him for a couple of weeks to buy an EGR kit. must be very busy, hopefully you'll get a reply & advice. Quote Link to comment Share on other sites More sharing options...
101sean Posted June 7, 2010 Share Posted June 7, 2010 If you look in the Nanaocom manual it says to check the numbers on the injectors themselves, I think because of the different types of injectors it can't always read them although it read mine ok. Quote Link to comment Share on other sites More sharing options...
black-ibex Posted June 7, 2010 Share Posted June 7, 2010 My understanding is that Nanocom (or any other diagnostics) cannot "read" the actual injectors, only what is currently stored in the ECU. Therefore if the ECU has been changed in the past and the actual codes from the top of the injectors have not been re-entered it will not give the correct reading. This may explain why they are all the same? As you now have the numbers from the top of the injectors, it is now simply a matter of using Nanocom to "write" them to the ECU. Dave... Quote Link to comment Share on other sites More sharing options...
