pandyst Posted May 30, 2010 Share Posted May 30, 2010 Hi there i have a p38 its has a power drain problem , I have replaced the battery but i also have a central locking problem and on reading a few post s i was wondering if its possible to be a Becm problem where its constanly awake because of a sticku actuator for example ? Any Suggestions are welcome thankyou . Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 30, 2010 Share Posted May 30, 2010 not sure if its the same... but our old Disco 2 had the problem of the battery draining, new battery etc. found out in the end that it was the batteries in the remote were low so the car wasnt being shut down fully. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted May 30, 2010 Share Posted May 30, 2010 You could try disconnecting the R/F ariel but have a look hear http://www.rangerovers.net/newrremedies.htm Quote Link to comment Share on other sites More sharing options...
Reg Posted June 5, 2010 Share Posted June 5, 2010 With a good battery the P38 will normally try to reset a bad door lock by repeating the sequence, i.e. the locks will click, pause, lift click, pause close click. The trouble with this is as I found on my 1st HSE was that due to a sticky tailgate latch, the process repeated ad infinitum , stupid computer didn't know when to give up!! Quote Link to comment Share on other sites More sharing options...
