Jinx Reyneke Posted May 31, 2010 Share Posted May 31, 2010 I've changed the lift pump on my TDI 300 and I've not remembered which way around the pipes go. Right now I have the top one connected to the fuel filter. Is this right? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2010 Share Posted May 31, 2010 Sounds correct if I remember right - in the bottom and out the top. Les. Quote Link to comment Share on other sites More sharing options...
Jinx Reyneke Posted May 31, 2010 Author Share Posted May 31, 2010 Thanks I went and took the old pump and did a brilliant thing. pumped it manually the bit that runs on the cam and put each in my mouth. pumped and the top is the suction side from the tank the bottom is the out to the filter and eventually to injector pump. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 31, 2010 Share Posted May 31, 2010 Is that a bit of bush tech then, Jinx ? Mo Quote Link to comment Share on other sites More sharing options...
