miss fire
hi i have a 2.5td when its under load it has a miss fire but in tickover its fine has anybody got any advise before i start buying bits randomly?
I'd go for a timing issue first, as it isn't doing it all the time (so not injectors).
When you say under load, is that always or only at high revs or only at low revs?
When did you last do the timing belt (and fuel filter)?
the timing was done 18 months ago and it was spot on but the cogs where showing sighns of wear the filters where done about the same time it only happenes when i chang to 4th 0r 5th until the revs pick up or going up a steep hill
