TonkaIIa Posted May 31, 2010 Share Posted May 31, 2010 Hi all, I'm currently installing the clutch and brake pedals on the series IIa, the current brake & clutch reservoir tank is the old metal one which is rusty...say no more! Is there a replacement available in plastic? if so, were is the best place to purchase. The current system on the motor is the signal brake line with no servo. Regards Gary Quote Link to comment Share on other sites More sharing options...
Gazzar Posted May 31, 2010 Share Posted May 31, 2010 Hi all, I'm currently installing the clutch and brake pedals on the series IIa, the current brake & clutch reservoir tank is the old metal one which is rusty...say no more! Is there a replacement available in plastic? if so, were is the best place to purchase. The current system on the motor is the signal brake line with no servo. Regards Gary Pegasus Bulkheads were talking about making up the old tanks again - you might send them an email and see if they ever got around to it. Failing that try LR series or Craddocks. G. Quote Link to comment Share on other sites More sharing options...
western Posted May 31, 2010 Share Posted May 31, 2010 90/110 have a single line clutch master cylinder but still use a alloy tank, some have a metal cap, later vehicles have a plastic cap similar to the brake master cylinder, IIRC Td5 Defenders use a plastic tank & cap but not sure if the actual cylinder is the same as earlier vehicles. Quote Link to comment Share on other sites More sharing options...
