Steve Warman Posted May 31, 2010 Share Posted May 31, 2010 Hi, Can someone confirm which side of the coil (Pos or neg) the wiring from the ignition and the wiring to the fuel cutoff solenoid should be to? I've found on here a wiring diagram that shows the wiring going to the negative terminal but would like some confirmation to see if I'm going nuts. I know theres a connection to the dizzy as well but the 2 mentioned go to the same side so would asnwer my question. Thanks Steve Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted May 31, 2010 Share Posted May 31, 2010 Assuming the vehicle is negative earth (all 90/110's were I think) then the supply from the ignition switch and the wire to the fuel solenoid go on the positive terminal. The engine will still run with the coil connected the other way round. You wont notice any difference! Quote Link to comment Share on other sites More sharing options...
