stealthmarine Posted June 2, 2010 Share Posted June 2, 2010 Hi I hope that someone can help me, I have a 1987 90, it has an overheating problem, up hills the temp guage goes near the red downhills it comes back down again. About 2/3rds of the little filaments are missing from the radiator, so I thought I would replace it, how do you get the plastic cowl around the fan out? cheers john Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 2, 2010 Share Posted June 2, 2010 This thread will give you some pointers - http://forums.lr4x4.com/index.php?showtopic=7880 Or - http://forums.lr4x4.com/index.php?showtopic=13599 Les. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted June 2, 2010 Share Posted June 2, 2010 Hi I hope that someone can help me, I have a 1987 90, it has an overheating problem, up hills the temp guage goes near the red downhills it comes back down again. About 2/3rds of the little filaments are missing from the radiator, so I thought I would replace it, how do you get the plastic cowl around the fan out? cheers john i did the same job on mine a month ago now i dont overheat no matter what i do it reaches half way and thats it. as for the cowl i drilled the rivits out and put self tappers in instead (its in 2 halfs) Quote Link to comment Share on other sites More sharing options...
stealthmarine Posted June 4, 2010 Author Share Posted June 4, 2010 i did the same job on mine a month ago now i dont overheat no matter what i do it reaches half way and thats it. as for the cowl i drilled the rivits out and put self tappers in instead (its in 2 halfs) thankyou both very much cheers john Quote Link to comment Share on other sites More sharing options...
