SolihullBeast Posted June 2, 2010 Share Posted June 2, 2010 Just a quick one; Will a fanbelt and alternator belt from a 200tdi defender, fit a 200tdi discovery? Done a bit of trawling around the forum, to no avail! Cheers Sam Quote Link to comment Share on other sites More sharing options...
scube Posted June 2, 2010 Share Posted June 2, 2010 I believe it will. 300 TDi have two versions Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 2, 2010 Share Posted June 2, 2010 The part is not common to both engines............. The part number for the Defender (11L Engine) is ETC7939 The part number for the disco (12L Engine) is ETC7469 As the part numbers are different, I would guess that there is a slight length difference........... Quote Link to comment Share on other sites More sharing options...
doda456 Posted June 3, 2010 Share Posted June 3, 2010 They will probably fit, without any major problems, theres only one way to find out. . . But a 200tdi does have a fair bit of slack adjustment as I was running a v8 efi alternator belt on my 200tdi disco , for a bit. It worked but the alternater was at the end of its travel Quote Link to comment Share on other sites More sharing options...
simonr Posted June 3, 2010 Share Posted June 3, 2010 Don't take this as absolute - but I remember someone saying that one will fit the other, but not the other way round, but for the life of me I can't remember which way round! Si Quote Link to comment Share on other sites More sharing options...
GBMUD Posted June 4, 2010 Share Posted June 4, 2010 The alternators will fit, the belts will not IIRC. The reason being that the water pump on the Disco is located lower down - they have different front housings. A new belt is only a couple of quid, buy two and keep one as spare. I have only needed a spare once on my Landrovers, but on the side of a French Autoroute I was glad to have had it! Chris Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 6, 2010 Share Posted June 6, 2010 200tdi disco alternator won't fit defender as it's the wrong hand. The 300tdi aircon model disco alternator will fit def 200. No idea about the belts I'm afraid Quote Link to comment Share on other sites More sharing options...
