lapperz Posted June 2, 2010 Share Posted June 2, 2010 hi im losing clutch fluid, and i cant seem to find where its coming from, any ideas please,it takes a week or two to fully empty, then clutch bites right at the bottom land rover 90 1986 2.5 n/a cheers Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2010 Share Posted June 2, 2010 is there any fluid dripping from the bll housing drain hole [where the wading plug fits] ? if yes, the slave cylinder seals have given up, best to change master & slave cylinders. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 2, 2010 Share Posted June 2, 2010 I don't know where this paranoia comes from about having to replace the clutch and slave if only one of them fails. I've changed one or the other only many times and never once had to go and do the other. Stupid old wives tale in my opinion. Replace what needs replacing and then worry about the other if and when it fails. Les. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2010 Share Posted June 2, 2010 I don't know where this paranoia comes from about having to replace the clutch and slave if only one of them fails. I've changed one or the other only many times and never once had to go and do the other. Stupid old wives tale in my opinion. Replace what needs replacing and then worry about the other if and when it fails. Les. Les, I think it comes from the poor quality slave and master's out there today, if one is on it's way out the other will not be far behind....... Given that the cost (probaly due to quality) is fairly low compaired to the bother of draining/bleeding the system again I think is why people do both. Jason. Quote Link to comment Share on other sites More sharing options...
lapperz Posted June 2, 2010 Author Share Posted June 2, 2010 is there any fluid dripping from the bll housing drain hole [where the wading plug fits] ? if yes, the slave cylinder seals have given up, best to change master & slave cylinders. hi do you mean the wading plug at the front, Quote Link to comment Share on other sites More sharing options...
love2learn Posted June 2, 2010 Share Posted June 2, 2010 its overkill we love overkill, its that british belt and braces approach. same as changing yer knickers an socks....errrr not that i wear knickers Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2010 Share Posted June 2, 2010 hi do you mean the wading plug at the front, at the front bottom of the gearbox, not engine Quote Link to comment Share on other sites More sharing options...
