dirtydiesel Posted May 17, 2006 Share Posted May 17, 2006 15 degrees of positive castor here we come, See told you it bolted on (to my jig!), And a few webs for good measure, Quote Link to comment Share on other sites More sharing options...
dollythelw Posted May 18, 2006 Share Posted May 18, 2006 looks a bit thin..... good work fella Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted May 18, 2006 Share Posted May 18, 2006 Thats how I did mine, not as many webs tho. We did brace from the top of the flange to the radius arm bracket to give a bit of support on heavy landings. Later on I also chopped it by the diff and turned it to give a bit more clearance on the starter. Never had any problems. One other thing we did whilst the casing was apart was to replace the diff pan with a thicker one from Simmonites. I then ran without a diff guard. Photo by Mark Fell Quote Link to comment Share on other sites More sharing options...
will_warne Posted May 18, 2006 Share Posted May 18, 2006 See told you it bolted on (to my jig!), Nice Jig I'm looking to build one soon for doing 3 link brakets. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted May 18, 2006 Share Posted May 18, 2006 And a few webs for good measure, And we know this method works well, we did this to my series 3 years ago, and they have NEVER moved, under serious abuse under cart springs! He's not mentioned the tapping out to M12 on the ends as well (a superb little bit done by me ), this has also proven itself when used with cap heads. This particular axle case does look so right in the flesh. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted May 18, 2006 Author Share Posted May 18, 2006 One other thing we did whilst the casing was apart was to replace the diff pan with a thicker one from Simmonites. I then ran without a diff guard. No poblems on that front, the axle is fitted with the tomcat strengthening kit. Replacing the swivel bolts with m12 cap heads is really effective, totally alleviates weaping swivel problems Quote Link to comment Share on other sites More sharing options...
muddy Posted December 19, 2014 Share Posted December 19, 2014 Bump Dan/Rog what did this axle go on, what was it used for and how did it perform? Will. Quote Link to comment Share on other sites More sharing options...
