Francis Posted June 5, 2010 Share Posted June 5, 2010 My disco's tyres are wearing extremely quickly (within a month, to bald) in the inside 50% on both sides. I have been reading some things about toe-in...also that there is no adjustment for camber. Am I doomed? Is there anything other than the axle that could be bent and need replacing? Quote Link to comment Share on other sites More sharing options...
PoguesTD5 Posted June 5, 2010 Share Posted June 5, 2010 Do you know if the Disco has had a new drag link or drag link ball joints. If it has and not been set up correctly then this would probably be the cause of the tyre wear. Quote Link to comment Share on other sites More sharing options...
Niamh Posted June 5, 2010 Share Posted June 5, 2010 How's your tracking? Niamh Quote Link to comment Share on other sites More sharing options...
henrycrabbe Posted June 5, 2010 Share Posted June 5, 2010 Hi Francis, just a few Q's... What flavour disco do you have? (age, engine type etc) What wheel/tyre size combination do you run? Cheers, Steve. Quote Link to comment Share on other sites More sharing options...
redgolf Posted June 5, 2010 Share Posted June 5, 2010 My disco's tyres are wearing extremely quickly (within a month, to bald) in the inside 50% on both sides. I have been reading some things about toe-in...also that there is no adjustment for camber. Am I doomed? Is there anything other than the axle that could be bent and need replacing? Front wheel toe out should be 0 to 2mm castor angle 3 degrees camber angle Zero It's unlikely to be castor or camber unless it's been messed with, As for tracking I always set that parallel, If it's good enough for racing cars then it's good enough for a Land Rover Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 7, 2010 Share Posted June 7, 2010 Sounds like massive toe-out if the inner parts are wearing. If you haven't replaced anything recently, maybe something has got bent? Regards Nigel Quote Link to comment Share on other sites More sharing options...
Andy Posted June 7, 2010 Share Posted June 7, 2010 Check your swivel bearings, if they go the wheel folds up outside the axle so all the load goes on the inner edge of the tyre. Quote Link to comment Share on other sites More sharing options...
JohnnyB_300TDI Posted June 10, 2010 Share Posted June 10, 2010 How are the steering bars? Quote Link to comment Share on other sites More sharing options...
