CR88 Posted June 7, 2010 Share Posted June 7, 2010 Hi dual brake line, solid disc is from 24 spline disco or a 10 spline??? how it look like, just the exterior of one 24 spline 300tdi discovery? any idea? cheers Quote Link to comment Share on other sites More sharing options...
Mark Posted June 8, 2010 Share Posted June 8, 2010 Carlos, are you looking at a front or a rear axle? On a front axle, both callipers have 2 brake lines for 200 and 300. On a rear axle, a 200 axle has a single brake line which goes to a T and then to each calliper. On a 300 axle, there will be 2 separate brake lines coming from the axle. On a rear, the 300 axle will only have 3 holes in the diff nose, whereas a 200 will have 4. There are other differences, but it would be good to know if you are looking at front or rear... hth Mark Quote Link to comment Share on other sites More sharing options...
CR88 Posted June 8, 2010 Author Share Posted June 8, 2010 Carlos, are you looking at a front or a rear axle? On a front axle, both callipers have 2 brake lines for 200 and 300. On a rear axle, a 200 axle has a single brake line which goes to a T and then to each calliper. On a 300 axle, there will be 2 separate brake lines coming from the axle. On a rear, the 300 axle will only have 3 holes in the diff nose, whereas a 200 will have 4. There are other differences, but it would be good to know if you are looking at front or rear... hth Mark Hi, thanks for the info, very interesting indeed. the biggest doubt was the front axle, but the info you told me about the rear is welcome as wll. thanks Quote Link to comment Share on other sites More sharing options...
mobi Posted June 8, 2010 Share Posted June 8, 2010 Carlos, are you looking at a front or a rear axle? On a front axle, both callipers have 2 brake lines for 200 and 300. On a rear axle, a 200 axle has a single brake line which goes to a T and then to each calliper. On a 300 axle, there will be 2 separate brake lines coming from the axle. On a rear, the 300 axle will only have 3 holes in the diff nose, whereas a 200 will have 4. There are other differences, but it would be good to know if you are looking at front or rear... hth Mark i have a 1996 300 and i have 1 line to each of the front callipers and a friend has a 1991 200 has 2 lines to each calliper, and as for the rear i have 1 line from the body axle which goes to a T piece. Quote Link to comment Share on other sites More sharing options...
gripper Posted June 13, 2010 Share Posted June 13, 2010 i have a 1996 300 and i have 1 line to each of the front callipers and a friend has a 1991 200 has 2 lines to each calliper, and as for the rear i have 1 line from the body axle which goes to a T piece. so does my 98 300tdi, 1 line to each front and 1 line to rear which splits in a T piece to each side. Quote Link to comment Share on other sites More sharing options...
