custom fuel tank and pumps
Guest noggy AKA Mortus
Guest noggy
Im currently trying to work out what to do with the fuel tank situation on my 200tdi disco
Ive found a tank with a feed/return and breather so is suitable for diesel. But it needs to be used with an external fuel pump, now what pump would i need to use?
What diesel cars use external fuel pumps and that i can pick up from the scrappers for chips?
On my comp truck i have two tanks a standard 90 main one and reserve to extend the range with out having to carry jerry cans etc..
i just xfer the diesel across to the main tank using an old SU pump (like you would find on a rangy) works fine.
but if you only have the one tank surely the lift pump on the engine will do the job?
Why do you need a pump?
I had a custom tank in my RR bobtail that had feed return and breather and I just connected it up to the fuel lines. Engine ran fine. If you think about it, that is how all 200TDI defenders and Discos are connected - there is no pump in the tank or the lines other than the lift pump on the engine.
If you are interested, I still have the custom tank - 17 gallons, sculpted to sit over the wheel arch on the passenger side HERE
