235/85R16 in Defender 110
2.4m to the top of the ladders/highest part of the roofrack as there is a Jerry Can holder on the back which is a bit taller.
2.45m to the top of the roof tent.
No lift kit.
Not sure they are a good idea on a Defender with extra roof weight, and the Camel ones didn't run a lift. I've not seen the need for a lift as it's for trips, not extreme off-roading.
Top90 Now I'm intreagued at your height. Your roof rack must be 14inches above the roof, Is it ?
My Defender is on 235 tyres. the rear springs are red/ green with 130 helper springs, which I understand Camels were fitted with. My top box is 11" hight and two inches from the roof, I need 2.3 metres height clearence.
The helper springs should lift the rear by 1.5"
Yes, the top of the roofrack is about 14" above the height of the roof of the 110.
That's the section near the back that holds four Jerry Cans as it sticks up higher than the rest of the roofrack.
 Share
