Chiraagshah Posted June 10, 2010 Share Posted June 10, 2010 Hey guys, We have a 1972 Range Rover Classic on portals that we use to compete in the rhino charge in Kenya. Been finding that electrical winches are a pain ... is there anyway to get a power take off for the Range's 4 Speed gearbox (I think its the LT95 box) so that we can run a PTO winch? All thoughts, suggestions most welcome as always! Many thanks, Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 10, 2010 Share Posted June 10, 2010 Crank-drive offers more flexibility if you have room for that. The RR gearbox has a PTO hole, and was used in the 101FC so there may well be a PTO for it out there. Overdrives for it (which bolt into the PTO hole) are reasonably common and go for around £100 last I saw, so that could provide the basis for a PTO unit. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 10, 2010 Share Posted June 10, 2010 Yes LT95 have 2 x types of PTO take of the rare as hell DROP PTO used to run the front winch, I spent 8 years hunting one of these for the old hybrid and sold it for a fortune And the other is a rear face PTO which ends up with a Prop 4 bolt flange, it would be possible to then adapter up something to bolt a Hydro pump etc, these are more common, about the size of a small bowling ball, and go for £200 + Happy hunting Nige Quote Link to comment Share on other sites More sharing options...
Chiraagshah Posted June 10, 2010 Author Share Posted June 10, 2010 Crank-drive offers more flexibility if you have room for that. The RR gearbox has a PTO hole, and was used in the 101FC so there may well be a PTO for it out there. Overdrives for it (which bolt into the PTO hole) are reasonably common and go for around £100 last I saw, so that could provide the basis for a PTO unit. Thanks Fridge - How would the Crank Drive work? If it links directly to the engine with no gears or clutch, hw would one control it if the engine was running? Quote Link to comment Share on other sites More sharing options...
Chiraagshah Posted June 10, 2010 Author Share Posted June 10, 2010 Yes LT95 have 2 x types of PTO take of the rare as hell DROP PTO used to run the front winch, I spent 8 years hunting one of these for the old hybrid and sold it for a fortune And the other is a rear face PTO which ends up with a Prop 4 bolt flange, it would be possible to then adapter up something to bolt a Hydro pump etc, these are more common, about the size of a small bowling ball, and go for £200 + Happy hunting Nige Thanks Nige ... not sure the second option would work - we seem to manage to break a lot of stuff out there and the more complex smething is the more likely to go wrong ... Will hunt for the drop pto but like you said ... its expensive. Only one found so far is in Aussie and he wants a kings ransom for it! May just end up going for a hydraulic winch instead ... Quote Link to comment Share on other sites More sharing options...
steve b Posted June 10, 2010 Share Posted June 10, 2010 You could always put the later Santana/LT230 in place of the 4sp , plenty of pto winch kits around for that set up , or as FF suggests , a crank driven Hyd pump and a Hyd winch , with the crank drive its possible with the right winch/motor set up to get drive-assist. hth Steveb Quote Link to comment Share on other sites More sharing options...
dave101 Posted June 10, 2010 Share Posted June 10, 2010 Hi I have a drop pto to fit the LT95 4 speed gearbox. I might be willing to sell if the price is right. PM me if you want more details David Quote Link to comment Share on other sites More sharing options...
