Paul64 Posted June 12, 2010 Share Posted June 12, 2010 Hi, This morning I heard a strange noise coming from the engine cavity, so I stopped to take a look. The water pump pulley wheel and the viscous fan were not turning symmetrically as if the pulley wheel itself was loose. I stopped the engine and could feel play in the pulley of maybe a couple of millimetres. The bolts holding the pulley on are tight so does that mean that the water pump bearings are failing? Thanks in advance. Paul Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 12, 2010 Share Posted June 12, 2010 Hi, This morning I heard a strange noise coming from the engine cavity, so I stopped to take a look. The water pump pulley wheeland the viscous fan were not turning symmetrically as if the pulley wheel itself was loose. I stopped the engine and could feel play in the pulley of maybe a couple of millimetres. The bolts holding the pulley on are tight so does that mean that the water pump bearings are failing? Thanks in advance. Paul My 200Tdi is doing this, it doesn't seem to be leaking as of yet, but I've picked up a new airtex pump to replace it with. Quote Link to comment Share on other sites More sharing options...
sgnas Posted June 12, 2010 Share Posted June 12, 2010 Take the tension off the belt (spanner on the tensioner), see how much it moves then. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted June 12, 2010 Author Share Posted June 12, 2010 Just had another look at it and to be honest there is probably more that 2mm of play and when I slacked off the belt there was slightly more. I took a short video to demonstrate. No water leakage though. Do you think the play attributable to the water pump bearing? Thanks, Paul Quote Link to comment Share on other sites More sharing options...
sgnas Posted June 12, 2010 Share Posted June 12, 2010 I took a short video to demonstrate. It's not long for this world! Could do 500miles, could do 50miles. Get a spare sent out, then either change it as a precaution or when it breaks. Oh, and as above. Try and get an Airtex. Now the OEM to Landrover. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted June 12, 2010 Author Share Posted June 12, 2010 I have got a spare somewhere but I don't think it is an Airtex Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 12, 2010 Share Posted June 12, 2010 This happened to mine Paul ! One morning when I started it, there was a bang, I lifted the bonnet and the shaft had sheared I found the pulley and end of the shaft on top of the inner wing Mo Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 12, 2010 Share Posted June 12, 2010 There shouldn't be any play in the pulley/shaft. The type of seal inside means that it won't leak. The pump should be replaced asap - the more play in the shaft - the closer it is to completely failing. Les. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted June 13, 2010 Share Posted June 13, 2010 That's BA-AD! Personally I wouldn't run it another second... Quote Link to comment Share on other sites More sharing options...
Paul64 Posted June 13, 2010 Author Share Posted June 13, 2010 Just checked my box of parts and I do have a new spare Bearmach water pump and gasket. My past experience with Bearmach kit has been pretty good so hopefully not far off Airtex. Quote Link to comment Share on other sites More sharing options...
crwoody Posted June 13, 2010 Share Posted June 13, 2010 One of mine got like that a while back - finally seized up and shredded the fan belt half way across the Severn bridge I would get it sorted ASAP. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted June 15, 2010 Author Share Posted June 15, 2010 It was changed last night by a mechanic I know. It turned out to be a pig of a job as the pump had been off before and some of the nut ends were rounded off. He said he could change an army TD5 pump in about 30 minutes as apparently they are easier to get to, but with all the stuff that needed shifting out of the way on mine the job took about 90 minutes. The bearings had gone completely and the inner face plate had a monster groove in it caused by the rotating wheel as the bearings gradually failed. Nice new pump on now and all seems to be working fine Thanks for all your advice. Paul Quote Link to comment Share on other sites More sharing options...
