Mark Posted June 12, 2010 Share Posted June 12, 2010 I dropped the tank on the 110 last night. Having got it back together, the truck started very briefly, but then died. It now won't start.... I have been through the priming procedure (turn it on, let the pump to it's stuff, turn off, repeat 6 times), and have attempted to start with my floor on the floor, but I am getting no sig of fiing whatsoever. I have stripped down the Regulator housing, and cleaned (there was no sign of rubbish) re fitted, and again been through the priming procedure, but still nothing. Does anyone have any suggestions of other things I can check or bleed to get it to fire? Any help much appreciated. Cheers Mark Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 12, 2010 Share Posted June 12, 2010 Wasn't there a thing with the Td5s with pressing the accelerator pedal a certain number of times or something? And, I'm sure you've checked there, but airlocks in the filter etc.? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 12, 2010 Share Posted June 12, 2010 I found this, apprently from the manual: turn off the starter switch and wait for 15 seconds turn the starter key to position 2 and wait for30 seconds turn off the starter switch repeat steps 2 and 3 six times fully depress the accelerator pedal keeping the pedal depressed,start cranking the engine continue cranking the engine and as soon as the engine is running on all cylinders ease the accelator pedal back to approximately halfway and release the starter key the engine should now be running if not do it all over again Quote Link to comment Share on other sites More sharing options...
SiWhite Posted June 12, 2010 Share Posted June 12, 2010 As has been stated, turn ignition on and depress throttle fully 5 times to start the purge cycle. Do this a few times until the pump noticably quietens and no more sloshing from reg / pump / filter is heard. Then crank in bursts of 20 seconds - it may take a number of battery charges to go. Try a jump start to boost the battery - if the ECU doesn't get enough voltage it won't fire the injectors. Short of time now - will assist more tomorrow if required. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 13, 2010 Share Posted June 13, 2010 Another method you could try if its accessible, is jumper 12v onto the fuel pump and let it run for a minute or so without cranking the engine. Then put it back to normal and try to start. This means your not kicking the arse out of the battery winding the engine over while the system primes. I did just this on my disco (albeit a carbed engine, but same principle) battery wasnt particularly great and wouldn't take much cranking, was already starting to flag after a few goes, so i jumpered the fuel pump relay for a minute and then turned the key and it fired right up. Quote Link to comment Share on other sites More sharing options...
yella 90 Posted June 13, 2010 Share Posted June 13, 2010 if its really really stubbern like some are, a brief tow up the road will spring it into life i flattend 3 optima's on my comp truck one time before it eventually started. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 13, 2010 Author Share Posted June 13, 2010 Well, after letting everything settle over night, and leaving the battery on charge, several goes at the automatic purging as described above, and some persistent cranking saw the truck back running again. Just for future reference, the manual method described above, is exactly what the ECU does, but without most of the sitting turning it on and off. Everyone's input is much appreciated. Thanks Mark Quote Link to comment Share on other sites More sharing options...
