Nige P Posted June 14, 2010 Share Posted June 14, 2010 I am about to order VDO Coolant and Oil Temp gauges. I see thy come with 1/8 NPT senders, but there are alternatives. Would the 1/8 NPT fit my 200TDi, or do I need to order another size? Many thanks Nige Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 14, 2010 Share Posted June 14, 2010 5/8" UNF on the 200Tdi 1/8" NPT on 300Tdi. Quote Link to comment Share on other sites More sharing options...
Marco Posted June 14, 2010 Share Posted June 14, 2010 In 2007 I did modify a Land Rover sender to take a VDO one. ... just check this link: http://www.landroveraddict.com/smf/index.php?topic=361188.0 Cheers Marco Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2010 Share Posted June 14, 2010 In 2007 I did modify a Land Rover sender to take a VDO one. ... just check this link: http://www.landroveraddict.com/smf/index.php?topic=361188.0 Cheers Marco I've used Marco's method as well on my owm 200Tdi to fit a Td5 temp gauge/300Tdi sender & made another for Mo Murphy recently Quote Link to comment Share on other sites More sharing options...
Nige P Posted June 14, 2010 Author Share Posted June 14, 2010 Many thanks for that. I think I'll get a 1/8 NPT tap then. Nige Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 14, 2010 Share Posted June 14, 2010 The alternative is an off-the-shelf adaptor like I used on my Td5 gauges install to mate the 300Tdi temperature sender with my 200Tdi engine. Got mine from here: https://www.europaspares.com/INSTRUMENTS/SENDER_ADAPTORS__ETC/1_8_NPT_FEMALE_ADAPTORS_TO_SUIT_MALE_IMPERIAL_BLOCK_THREADS_2020.html Quote Link to comment Share on other sites More sharing options...
Marco Posted June 15, 2010 Share Posted June 15, 2010 The alternative is an off-the-shelf adaptor like I used on my Td5 gauges install to mate the 300Tdi temperature sender with my 200Tdi engine. Got mine from here: https://www.europasp...READS_2020.html That's also a very useful link! Cheers Marco Quote Link to comment Share on other sites More sharing options...
