roofracks
pugwash
Since every other panel will fit I can't see why not - the only difference is the distance between the axles, the bodywork is exactly the same dimensions.
<Sits and waits for someone to point out how wrong he is>
that's what i assumed. but i didn't know if the gutters were the same- if they are different then the roofrack won't mount properly!
jim i'm sure that if you want a 110 roof rack to fit a 109 then fruity, me and a sledge hammer can make sure that the gutters are in the right place :)
thanks all- in no particular order:
Paul- i realise that but i would like a useable vehicle after you guys have finished bashing it with a hammer
Bish- that would be both sensible and boring
dave- useful to know thanks
Phil- spot on chap- knew there would be someone around here who would know for sure!
