bushwhacker Posted June 27, 2010 Share Posted June 27, 2010 Hi all, One of the (older) guys in our club has a sweet Range Rover chassis, V8, Lightweight bodied vehicle that does not have power steering.( When he is pulling away up hill we all fall to our knees)O what a sweet sound. He uses it both offroad and onroad. He wants p/s very badly. Did the first RR come with no p/s. We beleive it to be a RR chassis as it has coils and 1 rear shock forward of the axle and 1 to the rear. Would it be possible to fit a p/s system to this sort of set up. It,s on a galvanized chassis but he wont mind a bit of grinding to have p/s. He would really appreceiate any help, thoughts and ideas on how to achieve the p/s system. Thanks Quote Link to comment Share on other sites More sharing options...
zim Posted June 27, 2010 Share Posted June 27, 2010 Just bolt on a power steering box and fit a pump to the engine and it should be good I broke a really old rrc and that had the 3 bolt style box, but i think a normal 4 bolt (found on disco's, defenders, rrc's ) will fit. V8's come with power steering pumps so brackets etc shouldn't be a problem to find. HTH Gordon Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted June 27, 2010 Author Share Posted June 27, 2010 Thanks for the reply. I will have a look at this very soon. Quote Link to comment Share on other sites More sharing options...
Pwyll Posted June 28, 2010 Share Posted June 28, 2010 We have just finished doing this very job on our RR based trialler. Used a Disco box and pump. If you have a V belt engine which I assume you have, you will need a 200 series pump as it has the correct pulley. You will proably need a Disco steering arm as the ends are a different configuration on the Disco. All in all it took me and my Dad two and a half days to put everything together. All I can add is that was well worth it! Regards, Paul Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted June 29, 2010 Author Share Posted June 29, 2010 Big thanks. Great information.If you think of anything else please send it on. Quote Link to comment Share on other sites More sharing options...
Pwyll Posted June 29, 2010 Share Posted June 29, 2010 Big thanks. Great information.If you think of anything else please send it on. Actually, there is one other thing. When you have it all plumbed in and start to bleed the air out, DO NOT stop the engine until all the air is out. If you do, you will have an ATF fountain from the resrvoir. Go on, ask me how I know! Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted June 30, 2010 Author Share Posted June 30, 2010 Thanks. I think I know how you know. It's usually the way I learn to. Quote Link to comment Share on other sites More sharing options...
meathumper Posted July 2, 2010 Share Posted July 2, 2010 I fit a full system to a ex marine 90. Took about 6 hours, and cost £40 for parts. Parts for a rangie are easy to come by, I would go for a four bolt box. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted July 5, 2010 Author Share Posted July 5, 2010 Cheers. Yes I think 4 bolt is the way. I can now tell our member it is do able,and he can hold onto his V8 Lightweight body Range Rover chassis hibrid. Quote Link to comment Share on other sites More sharing options...
