Finn Posted June 28, 2010 Share Posted June 28, 2010 This came together with a fairey winch and series pto I bought from Steve. I have asked him if he knows what it is for, but he has not replied yet. Looks like an adapter plate.. Has anyone got an idea? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
jad Posted June 28, 2010 Share Posted June 28, 2010 google...... http://www.britishparts.com/product.php?productid=3006516&cat=138901&page=1 Quote Link to comment Share on other sites More sharing options...
Finn Posted June 28, 2010 Author Share Posted June 28, 2010 But what is it used for? It is used on a disco.. so its not a part of the fairey winch / pto combination? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
western Posted June 28, 2010 Share Posted June 28, 2010 it's part of the bearing carrier on the transfer box where the PTO or overdrive fits, probably been removed to fit the Winches PTO unit. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 28, 2010 Share Posted June 28, 2010 the PTO should only replace the cover plate, not the bearing carrier surely? Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 28, 2010 Share Posted June 28, 2010 Ralph got there first. Looks like the bearing carrier. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted June 28, 2010 Share Posted June 28, 2010 It is the rear bearing carrier. In one of the pics you can see part of the bearing outer race (also called the cup with taper roller bearings). The other parts of the bearing are mounted on the transfer case input gear. That bearing carrier is removable so the input gear can be fitted/removed from the transfer case. Sometimes when the rear cover (or a PTO that replaces the rear cover) is removed, the bearing carrier sticks to the cover (or PTO) - depends upon procedure used for how the parts are split at disassembly. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 28, 2010 Share Posted June 28, 2010 It's the outer bearing carrier for the standard output gear from the gearbox to the transfer box. I'm not too familiar with the Fairey winch, but it might be surplus to requirements. Some winches/ Overdrives are fitted with the cover plate and outer bearing cariier removed, and some are not. Les. Quote Link to comment Share on other sites More sharing options...
Finn Posted June 29, 2010 Author Share Posted June 29, 2010 But what I don't understand, what does a disco part do on a series PTO? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted June 29, 2010 Share Posted June 29, 2010 But what I don't understand, what does a disco part do on a series PTO? Cheers, Finn Possibly it just got mixed up in the wrong 'box of bits'. If it doesn't fit your gearbox, but all the other bits do, there is nothing missing, and the PTO works, then it's surplus to requirements. Regards. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted June 29, 2010 Share Posted June 29, 2010 But what I don't understand, what does a disco part do on a series PTO? Cheers, Finn Absolutely nothing. Quote Link to comment Share on other sites More sharing options...
Finn Posted June 29, 2010 Author Share Posted June 29, 2010 ok, thanks guys! Quote Link to comment Share on other sites More sharing options...
Bush65 Posted June 29, 2010 Share Posted June 29, 2010 People have used different names for the same parts, which may lead to some confusion. So I have included pics from the LT230T Overhaul Manual. The item in question is item number 9 in these pics. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 29, 2010 Share Posted June 29, 2010 Also see: Fairey 525 drop-PTO fitting manual (LT230) Or slightly later: H14W hydraulic PTO winch fitting manual (also LT230) Quote Link to comment Share on other sites More sharing options...
Finn Posted June 30, 2010 Author Share Posted June 30, 2010 By the way.. would this also fit to an lt230 defender box? Cheers, Finn Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 30, 2010 Share Posted June 30, 2010 It doesnt look quite like the one from my LT230 - my bearing carrier doesnt have all those cut out/hollow sections in it, it is solid. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 30, 2010 Share Posted June 30, 2010 It it fits an LT230 it fits an LT230, should interchange with anything. The "extra" holes I believe are oiling for the PTO / input gear, early LT230's suffering input spline wear hence the later cross-drilled input gear. Quote Link to comment Share on other sites More sharing options...
