brighouse shed Posted June 30, 2010 Share Posted June 30, 2010 Hi usual drivers footwell rotting except mine is going from the top the bottom being solid. the only rotten bit is the top piece above the section with cutouts for the pedals plus the side panel next to the door my questions 1. should i cut it all as one piece and put 10mm tabs along the edges to weld to good metal. 2. there are some bolt fittings which the footwell does not seem to have any contact to, should it actually be fastened in by these? thanks Quote Link to comment Share on other sites More sharing options...
