Mark90 Posted August 25, 2005 Share Posted August 25, 2005 What if any are the drawbacks of fitting the temp sender (capillary type) in the top hose rather than the usual position in the inlet manifold. This is a 4.2 V8 on carbs we're talking about. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 25, 2005 Share Posted August 25, 2005 It won't work when the thermostat's shut...? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 25, 2005 Share Posted August 25, 2005 Doesn't the thermostat have a bleed valve in it, so you would still get an accurate temperature reading if it's shut?? Les. Quote Link to comment Share on other sites More sharing options...
