madmatt Posted July 8, 2010 Share Posted July 8, 2010 Evening all, I have a 97 300TDI defender I would like to know the sizes of bolts that hold the power steering box on both diameter lengths and thread if possible please? I think its 6 bolts in total I need to source new ones before i remove the old ones or I can't fetch them lol! Many Thanks Matt Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted July 8, 2010 Share Posted July 8, 2010 There are 4 bolts. M12 x 100, 10.9 quality. Sorry don't know the length of thread off hand. HTH. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 8, 2010 Share Posted July 8, 2010 http://www.lrseries.com/shop/product/listing/3621/BX112201-BOLT-STEERING-BOX-M12-X-100.html Just get four M12 x 100mm bolts in 10.9 or greater grade from your local fasteners place. Quote Link to comment Share on other sites More sharing options...
nick w Posted July 11, 2010 Share Posted July 11, 2010 make sure you use nylock nuts or nut lock they can shake lose Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2010 Share Posted July 11, 2010 Matt, go to the part number forum & look through the 110 parts book link, you can find all the numbers there, make a note & put them into LRSeies to find the bolt details, length. Quote Link to comment Share on other sites More sharing options...
errol209 Posted July 11, 2010 Share Posted July 11, 2010 make sure you use nylock nuts or nut lock they can shake lose They are supposed to have locking tab plates under the heads, part number 572077, 2 no. required. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 11, 2010 Share Posted July 11, 2010 The chassis rail bolts screw into the steering box, so no nuts there. Locking tabs (or you could use spring washers instead). They are M12 x 1.75 pitch x ? length. There are also 2 x nuts/bolts that connects the support bracket at the bottom of the steering box - these are also M12 x 1.75 and (I guess) 25-30mm. Large washers either side and nyloc nuts on them. Les. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 2, 2017 Share Posted September 2, 2017 Mega necro-post I know, but saves creating a new thread. As above the part number for the 4 M12 steering box bolts was BX112201 - a standard hex-headed bolt 100mm long. This has apparently been superseded by QYG500140, of which I ordered four for my 110. However these are flange-headed as below, with threadlock on. This means the captive strips won't work, they're also slightly shorter than 100mm (due to the flange) which, combined with the captive strip and a washer, makes me worried about sufficient thread engagement at the box end. Has the fixing method for 2007-on vehicles changed, to do away with the strips/washers and rely on the flanged heads and the threadlock? I need to find a 2007-on vehicle to look at but wondered if anybody knew? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted September 2, 2017 Share Posted September 2, 2017 Not to worry, saw a 62-plate 110 in town and had a sneaky look so have answered my own question. For reference, it would seem that 2007-on they used these later flange-head bolts and no captive strip or washers. I suspect the threadlock negates the need for the former and the flanged head for the latter. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted September 2, 2017 Share Posted September 2, 2017 Less parts and faster to build the truck on the production line. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 4, 2017 Share Posted September 4, 2017 Looks like they are necked as well; I'd grease under the flange to ensure they tighten enough, and if, ie when, ,you come to do undo them to make sure you can Quote Link to comment Share on other sites More sharing options...
