nickwilliams Posted July 14, 2010 Share Posted July 14, 2010 As posted about previously, I'm re-building my RHD 1990 90 onto a new galv'd chassis and converting from a 2.5TD to a 300 TDi at the same time. I've now got the bulkhead fitted and have come to fit the clutch pedal and pipework today. I've got a 300 TDi slave cylinder (and the associated bracket, short metal pipe and the widget which switches the pipe through 180 deg.) but I was planning to use the original master cylinder. The 19J clutch slave is on the LH side of the engine, whereas the 300TDi is on the RH side so I need a short metal pipe rather than the old long one since the fixed piping no longer crosses the rear of the engine. I also find that the thread for the flexible pipe used on the 19J slave cylinder is a different thread to the one in the widget on the 300 TDi slave. I fear this means that the thread on the '300 tdi' master cylinder is also different, so even if I buy the correct combination of flexible and fixed pipe I will find that it won't fit at the master cylinder end. Can anyone advise a combination of part numbers for the metal and flexible pipes which will provide an off the shelf solution, or, failing that, at least confirm that no such thing exists? I suppose the key question is whether or not the master cylinder pipework threads are different. Thanks NIck Quote Link to comment Share on other sites More sharing options...
western Posted July 17, 2010 Share Posted July 17, 2010 Refer to http://forums.lr4x4.com/index.php?showtopic=55181 pinned at the top of this forum, for all to access. also if your keeping the original LT77 gearbox 300 Tdi + LT77 Conversion Quote Link to comment Share on other sites More sharing options...
