Phillis Posted July 16, 2010 Share Posted July 16, 2010 Are britpart Hd clutches any good? there alot cheaper than others such as ap? or are AP really alot better than Britpart.. Its to go in a 200tdi 90 Quote Link to comment Share on other sites More sharing options...
jbs Posted July 17, 2010 Share Posted July 17, 2010 Please Do Not buy a britpart clutch as it won't last 5 minutes! Do yourself a favour and fit a decent make like borg and beck AP lockheed etc also make sure it's for the 130-even though I know you have a 90 by what you've typed,they the same size plate but mucho HD as it will be a HD clutch plate/kit and remember to replace the clutch fork and make sure if you can to reinforce it there is a mod for the fork-which you will need to do some welding or get some welding done to reinforce the point on the fork on the front of it where the ball on the rear of it pivots look here and it may prove a good idea to replace the master and slave cylinders too-if you can't/don't remember when the last time they were changed HTH John Quote Link to comment Share on other sites More sharing options...
